McGarnagle
Nov 17, 2017Aspirant
TrueCrypt container
Hi I currently store a few TrueCrypt containers on my ReadyNAS 316. I use TryCrypt to mount these containers when i wish to copy/paste additional files into the container. This has always worked f...
- Dec 04, 2017
I have a new local build of the SMB Plus app that adds an option for this setting. Get it from here, and install from the Apps tab, using the Upload button. Then launch the SMB Plus app, go to the Write Options tab, and disable Strict Sync.
We plan to make this a per-share option in a future firmware release.
Skywalker
Dec 07, 2017NETGEAR Expert
It doesn't make sense that Strict Sync would have already been set to disabled, unless you ran the command I posted earlier from a terminal. Maybe there's some strange browser issue with the SMB Plus app? In any case, I can take a look to confirm that the proper setting is in place if you enable Secure Diagnostic Mode and PM me the 5-digit number.
McGarnagle
Dec 07, 2017Aspirant
Hi SkyWalker
I did a little more checking. It appears that the problem only persists for TrueCrypt 7.1a containers. VeryCrypt containers seem to work ok. I don't know if this makes sense but its probably good enough for me since i can simply make VeryCrypt containers and move everything there.
