McGarnagle
Nov 17, 2017Aspirant
TrueCrypt container
Hi I currently store a few TrueCrypt containers on my ReadyNAS 316. I use TryCrypt to mount these containers when i wish to copy/paste additional files into the container. This has always worked f...
- Dec 04, 2017
I have a new local build of the SMB Plus app that adds an option for this setting. Get it from here, and install from the Apps tab, using the Upload button. Then launch the SMB Plus app, go to the Write Options tab, and disable Strict Sync.
We plan to make this a per-share option in a future firmware release.
McGarnagle
Dec 08, 2017Aspirant
Actually, spoke too soon. I was looking at the wrnog thing. Looks like the problem persists for all containers. SkyWalker ive PM'd you the 5 didgit code as suggested.
Skywalker
Dec 08, 2017NETGEAR Expert
The strict sync setting looks good, but I see you've got the max protocol set to SMB1. SMB3 is much more efficient. Can you switch to that and then try some SMB transfers? I can monitor the system operations during the transfer to see where the bottleneck is.
