ReadyAS
Dec 13, 2019Guide
Turned off after power return
I would like to recall the thread: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Auto-Power-On-after-Power-Loss/m-p/896012/highlight/true#M49771 and ask about the possibility to ...
schumaku
Dec 14, 2019Guru - Experienced User
All the ReadyNAS are designed for 24*7 operations - so they have to power-up and boot if power is applied, e.g. following a power failure 8-)
I guess they removed the BIOS menu from these legacy unit, so the config (which does exist on industry standard systems) cant' be changed easily. Time for patching the defaults in the image?
If you are interested: The competitors are not sleeping - they have controls in the Web UI for BIOS- (top) and custom power controller equipped ARM systems (below) for a loooong time:
ReadyAS
Dec 14, 2019Guide
The processor for Pro4 (RNDP4000) and Ultra4(RNDP4000) has x86 (not ARM) architecture, but maybe is there Web UI for BIOS for that NAS'es?
Could you give me any tip how to find it, please?
- schumakuDec 14, 2019Guru - Experienced User
Yes, that's why one might hope that patching the default power up config might be possible - big risk, as what-if somethng goes wrong? The BIOS is well protected and hard to reach for modification of the configuration on a running system. If there would be a way to access the standard BIOS set-up screen (e.g. using a VGA-adapter and a keyboard) the old ReadyNAS freaks here would have discovered this long ago.
- ReadyASDec 14, 2019Guide
Correction: of course Ultra4 is RNDU4000, not RNDP4000
StephenB, I really appreciate your willingness to help and the fact that you provide a detailed solution. Thanks for this!
I use the NAS in a different mode, namely from time to time. I have several of them, but I use some of them every few days or even weeks. I just have a backup there and synchronize data from time to time.
If I turn on the NAS, then at 2:00 at night it automatically turns off (I waited for a long time for OS6 to have a function that only turns off the NAS. At first in OS6 there was only one that turned on and off, and that did not suit me).
I often go away and then turn off the power supply to the circuits at home. After returning, I turn on and all NAS'es turn on, regardless of what I did. There is just a supply voltage and they all turn on.
I want to move one or two NAS'es to other locations. They will be enabled only during backup. I do not want them to be exposed to voltage outages. Why? Because voltage flapping may occur. Even in this forum cases of damage to devices are described, when the voltage appears and disappears.
I expect one simple thing (and not only me): that it will simply not turn on itself (I'm always able to turn it on via WOL). I really like Netgear, but the lack of such functionality makes me think about changing the device to another brand, at least those that don't have UPS.
