ReadyAS
Dec 13, 2019Guide
Turned off after power return
I would like to recall the thread: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Auto-Power-On-after-Power-Loss/m-p/896012/highlight/true#M49771 and ask about the possibility to ...
schumaku
Dec 14, 2019Guru - Experienced User
For reliability reasons, I suggest always using a UPS - no hardware, no OS, and no file system does take power flips easy.
No idea if these legacy NAS with the OS6 "update" would allow WoL or controlling the power-up mode. For the "current" x86/BIOS models, I think the implementation would be feasible, WoL is certainly supported. The point is that Netgear seems to struggle in many areas and design changes and real product enhancements are difficult to achieve.
ReadyAS
Dec 15, 2019Guide
schumaku wrote:For reliability reasons, I suggest always using a UPS - no hardware, no OS, and no file system does take power flips easy.
Really is any problem to modify:
BIOS_Update_Package_0.5-x86.bin
and share the version with auto power off (permenently)?
- SandsharkDec 15, 2019Sensei
If at least one of the NAS is not always on (at least when any other is on), then sharing the UPS will be an issue. Something has to be on to share the info for the others.. The only way around this that I know of is to use an UPS that has a direct Ethernet connection and use SNMP to monitor it. I think that's available on the old OS4.2.x, but I know it's available on 6.x.
The BIOS update package doesn't change any settings, which are normally in CMOS, not flash memory. It's just a wrapper around the flashrom utility and the AMI-provided BIOS update source file.
With a VGA header installed, the user does have access to the BIOS on a Pro6, and I don't recall seeing a setting for power condition after power loss and recovery. The rack mount systems do have it, though. If there is no setting for it, there is no way to change it.
I'm not sure how the NAS is going to retain the power-on schedule through a power interruption if it doesn't come on at least long enough to re-boot and read the schedule again. That may be the driving factor for not providing an option.
- ReadyASDec 15, 2019Guide
Sandshark wrote:The BIOS update package doesn't change any settings, which are normally in CMOS, not flash memory. It's just a wrapper around the flashrom utility and the AMI-provided BIOS update source file.
Could explain it, expecially the second sentence, please?
Are you sure there is no way to change the power settings by modifying the BIOS bin file?
- StephenBDec 15, 2019Guru - Experienced User
True.
It is an option on OS 4.2.x also.
- SandsharkDec 16, 2019Sensei
The BIOS .bin file has the tools to update the BIOS flash chip with BIOS licensed from AMI. If there even is a setting for this, Netgear would have to contract with AMI to make a change to the default setting since nothing in the package changes the actual settings from the defaults. Settings are stored in battery-backed CMOS, not flash memory. Writing to that would require an entirely different tool, which may not even exist..
- ReadyASDec 29, 2019Guide
There is no need to modify the bin file, flash the chip, etc.
I solved the problem simply changing one option in BIOS.
