BJB
Jan 19, 2016Aspirant
Upgrading my RN104 from 6.1.9
Greetings. I received some great advice on another thread but that was quite a while ago and it is closed. And I am just now finally getting around to this upgrade. My RN104 is on version 6.1.9...
- Jan 26, 2016
This is done.
Thanks,
BJB
mdgm-ntgr
Jan 24, 2016NETGEAR Employee Retired
Please send in a fresh set of logs downloaded after the update to 6.2.5
BJB
Jan 26, 2016Aspirant
This is done.
Thanks,
BJB
- BJBJan 26, 2016Aspirant
FYI, what I meant by "this is done" is I sent the logs. :smileyhappy:
May have replied to the wrong post .
BJB
- mdgm-ntgrJan 27, 2016NETGEAR Employee Retired
Bit-rot protection and snapshots will lead to a lot of fragmentation if used on shares that you backup to.
Your snapshots were not upgraded when you updated to 6.2.5. Do you still need those?
- BJBJan 27, 2016Aspirant
mdgm,
Since you are commenting on my snapshots I assume you got my logs? I do not need those snapshots. However I did not receive any message that they were not updated. Since they were not updated can I delete them in 6.2.5?
As far as share and bitrot settings, here are my shares. I have a backup share that is strictly for disk images. A picture share where images are copied there and stay there. No deleting. And a video share where things are added and occasionally streamed. No deleting. Just let me know the best share and bitrot settings for each or all of these.
And if I have to delete those shares or something let me know how and when. I guess I need to sort that out, set the right share and bitrot settings, then run my maintenance stuff, then upgrade whenever I want.
Thanks again,
BJB
I can remove these remotely. Would be best to do this before updating to 6.4 seeing how full your volume is.
Generally this is true: If files are regularly being modified in place then bitrot is bad. If you are mainly adding files but not editing them then bitrot is good.
- StephenBJan 27, 2016Guru - Experienced User
This is certainly true for snapshots - when files are modified in place, they end up fragmented, which will hurt performance.
AFAIK bitrot protection only needs the btrfs checksums. I don't see any particular reason why modifying files in place is a problem for the file system or for bitrot protection itself, as long as there are no snapshots kept for the share. Can you elaborate a bit more on your thinking here?
