jhyland
May 24, 2016Tutor
UPS keeps disconnecting and reconnecting
My UPS is connected by USB cable to my readynas RN104. I regularly get the message: Error communicating with UPS UPS (). Then I usually get a message shortly after: Communication with UPS UPS () is O...
jhyland
Jun 01, 2016Tutor
Thanks. I've emailed the logs.
jhyland
Aug 20, 2016Tutor
Hi,
Just checking in. I think I've given you ample time to look at this. I am still having the issue. What is the status?
Thanks,
Jonathan
- jhylandAug 29, 2016Tutor
Still need the help. Any advice?
- mdgm-ntgrAug 30, 2016NETGEAR Employee Retired
It seems BrianL didn't get your logs.
There could be a problem with the UPS. Have you tried connecting the UPS to another device e.g. your PC to see if monitoring works fine with that?
- jhylandSep 04, 2016Tutor
Thanks for the update. I just resent the logs. I hope they help. I have not connected the UPS to my PC (or another device) yet. I haven't found a maintenance window yet where I can bring down the NAS and the router and switch that are connected to it. That would bring down the whole network. Let's see if the logs provide any insight.
Thanks.
