jhyland
May 24, 2016Tutor
UPS keeps disconnecting and reconnecting
My UPS is connected by USB cable to my readynas RN104. I regularly get the message: Error communicating with UPS UPS (). Then I usually get a message shortly after: Communication with UPS UPS () is O...
Sep 04, 2016Guru - Experienced User
jhyland wrote:
I have not connected the UPS to my PC (or another device) yet. I haven't found a maintenance window yet where I can bring down the NAS and the router and switch that are connected to it. That would bring down the whole network.
You don't need to change your power connections. All you really need to do is move the USB connection - which won't bring down anything.
jhyland
Sep 04, 2016Tutor
Thanks. That's a good idea. I'm going to have to find a laptop I can put near the UPS and NAS. They are in a separate area from my desktop. Any insight from the logs?
- mdgm-ntgrSep 06, 2016NETGEAR Employee Retired
Do you have a USB disk connected to the NAS as well?
Do you still have the problem if the only USB device connected is the UPS? - jhylandSep 07, 2016Tutor
I do have a USB disk connected also. I use that for backups. I disconnected it for 12 hours for a test. Only the UPS was plugged in to a USB port on the NAS. The UPS still disconnected and reconnected itself 3 times durning that period. (I don't know if this is related, but the USB disk will disconnect itself, but that only happens every couple weeks).
Thanks.
- mdgm-ntgrSep 08, 2016NETGEAR Employee Retired
Can you try disabling disk spin-down and see if you still have the issue?
- jhylandSep 13, 2016Tutor
I have been running with the disk spin down feature disabled for several days now. I have not had the ups disconnection error during this time. I have had the USB disk disconnect though. How do I get both of the USB devices to stay connected while I am using the spin down feature?
- jhylandSep 28, 2016Tutor
Hi, Any update on this issue? I'd like to be able to use the disk spin down feature.
Thanks.
- JennCSep 29, 2016NETGEAR Employee Retired
Hello jhyland,
Did you already update to 6.5.2? ReadyNAS OS 6 Software Version 6.6.0 is also already available.
- JohnRoOct 03, 2016NETGEAR Employee Retired
Hi jhyland,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- jhylandOct 09, 2016Tutor
Thank you. The latest version of the firmware 6.6 resolved the ups connecting/disconnecting issue.
- JennCOct 10, 2016NETGEAR Employee Retired
Hello jhyland,
Thanks for confirming the new FW resolved the issue.
We encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
