basshead
Aug 25, 2016Aspirant
using second drive as first drive in another RN10200
My query is similar to an existing thread https://community.netgear.com/t5/Using-your-ReadyNAS/Swapping-discs-in-a-pair-of-ReadyNAS-s-s/m-p/1094089#M110332 I wondered if it would work, to remove ...
- Aug 26, 2016
basshead wrote:
The main purpose of the new ReadyNAS was to provide the redundancy achieved by using a second drive in the original ReadyNAS.
I get that, and I run jbod on my smaller NAS (which are used for backup). But you can't switch from raid-1 to jbod w/o destroying the volume. It would nice if you could, but the current firmware won't allow it.
So the volume will show up as degraded forever. And I don't think it will let you install a second disk as a new volume - it will want to restore the RAID-1 array.
basshead wrote:
It seems like a complicated process for little or no gain. One goal was to increase storage capacity before the existing volume fills up.
It is annoying, but the only way to cleanly do what you said you wanted to do. Which was (a) switch to jbod and also (b) replicate the current NAS volume onto the new one.
It's the conversion to jbod that's makes this messy - if you were running it already, it'd be simpler.
But you don't really have much data, going through these steps is perhaps 2 days (mostly waiting for backup jobs to complete).
basshead wrote:
Another solution could be to use the new ReadyNAS as a completely separate drive/volume, and distribute files between the two ReadyNASes accordingly (eg: keep music files on the old ReadyNAS, and all other files on the new ReadyNAS). The problem with this method is I don't have a backup of all files kept in a different physical location (ie: redundancy within the same ReadyNAS by use of a second drive doesn't protect against fire or theft).
Or just get two bigger drives for the new NAS, migrate the data, and rebulld the old NAS as the backup (two volume jbod). Then you can have the benefit of local RAID-1 and also have the benefit of disaster recovery.
Aug 28, 2016Guru - Experienced User
basshead wrote: Looking at the 202, it's double the price, for double the speed (200Mbit/Gigabit ethernet) which isn't on my radar yet...
Just to clarify: Your RN102 will max out at about 70 MB/s. Gigabit ethernet actually maxes out around 100 MB/sec, so in actual use the RN202 is perhaps 50% faster.
The 200 MB/s advertising assumes NIC bonding and a use case that fully takes advantage of both NICs. That isn't common for home NAS users.
A bigger advantage of the 200 series is that you get faster syncs, faster scrubs, balance. And apps run faster.
basshead
Aug 28, 2016Aspirant
70MB/s is way fast enough for my needs (primarily photo storage and data/documents backup), and given I don't use any of the app's (therefore CPU speed increase doesn't matter) makes the RN202 even less attractive, but I appreciate your pointing out the features (they may be attractive to others reading this thread).
