BaJohn
Feb 20, 2015Virtuoso
Read much slower than Write on ReadyNAS 516.
Running NAS Performance Tester Vers 1.7 on default setting (400MB with 5 loops) from my WIN 7 64bit PC over wireless gives these very slow results. Ave Write in MBps 5.65, 4.22, 5.33 and 4.46. Ave R...
RX
Feb 20, 2015Luminary
I believe you have already thought of this.... What if you try to run the same test again using the same PC but it should be directly connected to the WNDR4500 Router where the NAS is also connected to? - Lets see if it will make a difference on the results...
