BaJohn
Feb 20, 2015Virtuoso
Read much slower than Write on ReadyNAS 516.
Running NAS Performance Tester Vers 1.7 on default setting (400MB with 5 loops) from my WIN 7 64bit PC over wireless gives these very slow results. Ave Write in MBps 5.65, 4.22, 5.33 and 4.46. Ave R...
rovingmedic
Feb 22, 2015Tutor
WiFi network interference may be your biggest issue which will result in unpredictable performance. Not sure how you selected your current channel. You may want to set your router's channel manually to either channel 1, 6 or 11. Pick the channel that has the least amount of interference from other WiFi networks (fewest and weakest other networks). Also consider chatting to your neighbours to segregate the various networks onto non-overlapping channels. Here are some useful articles on the subject:
http://www.smallnetbuilder.com/wireless ... d-wireless
http://www.smallnetbuilder.com/wireless ... less-crowd
