BaJohn
Feb 20, 2015Virtuoso
Read much slower than Write on ReadyNAS 516.
Running NAS Performance Tester Vers 1.7 on default setting (400MB with 5 loops) from my WIN 7 64bit PC over wireless gives these very slow results. Ave Write in MBps 5.65, 4.22, 5.33 and 4.46. Ave R...
Feb 22, 2015Guru - Experienced User
Not sure why you can't get wifi working with the vista laptop.
(a) Are you using 5 ghz or 2.4 ghz wifi? 5 ghz has less interference, but doesn't travel as far. Not sure which is best for your setup.
(b) wifi interference and multipath are factors, and you probably should try changing channels.
Though I think you should look into getting some cat 6 cable installed in your home.
