eyewanders
Sep 12, 2016Aspirant
ReadNAS NV+ v3 will not power
Please help. Two nights ago our ReadyNAS was powered down normally to move to a different location. Nothing out of the oridinary happened. There is no hot or burned smell from the unit, but now it is...
- Sep 12, 2016
Well I suppose this can be marked as solved before it was ever replied. I contacted a friend/coworker who had an older gen-1 NV+ lying around not being used. I picked it up and swapped its PSU into my unit and I'm back up and running (and prepping for a giant data offload since I don't trust this PSU any more than the one that just failed, particularly since it's nearly 2 years older). At any rate, this takes care of my issue obvioulsy for the time being.
eyewanders
- mdgm-ntgrSep 12, 2016NETGEAR Employee Retired
Support do have the ability for this model to sell a replacement PSU whilst stocks last if the old PSU has failed.
However the NV+ v1 hardware revision 3 is quite an old model now. You can get much better performance with any of our current models.
- eyewandersSep 12, 2016Aspirant
It has indeed failed. Running fine for the time being with the donor PSU. I intend to move to a new NAS this week. May keep this one around for redundancy as long as it keeps chugging along. We'll see. Thanks for the reply. I did check and found replacements (PSU) for around $125 - clearly not a wise investment at this point.
- SandsharkSep 13, 2016Sensei
A replacement PSU is available for a much lower price if you don't mind swapping a couple pins on the connector. Search the forum for "legacy power supply" and see the post from me about this.
