BotanyBay
Aug 30, 2016Tutor
ReadNAS PRO 6 stuck at "Booting" after requesting download of logs
I have an ReadyNAS pro 6 which I noticed had failed complete a "pull backup" from a primary ReadyNAS Pro 6 because the file system of the backup unit became full. The primary ReadyNAS Pro 6 is c...
- Sep 01, 2016
mdgm wrote:
It sounds like you may have a large log file or perhaps even a full 4GB root partition.
For these kinds of issues there is per incident support available, but remote access to your NAS would be required.
If ssh is already installed on the NAS, you could access the OS partition yourself and likely find the file and truncate it. However once the OS partition is full, you won't be able to install the add-on to enable ssh.
So your other (painful) option is to do a factory reset on the NAS (which destroys settings and data), rebuild it, and restore the data from the primary NAS.
BotanyBay
Aug 30, 2016Tutor
Note that I do see the "Check FS" message on the front panel which completes quickly and then goes on to the "booting" message
- mdgm-ntgrAug 31, 2016NETGEAR Employee Retired
Did you discover which firmware is on the unit?
- StephenBSep 01, 2016Guru - Experienced User
- BotanyBaySep 01, 2016Tutor
Firmware version is 4.2.17
6 two TB disks in an xraid2 configuration.
ssh is not currently installed.
For the second unit (the primary) is there any risk is "clear logs", previously I had gotten to these machines every couple of months, downloaded the logs and then cleared them. I have not done a download logs on the primary machine at this point.
I suspect that rebuilding is the route I will go, I assume that if I do the following:
With the machine off
Remove all 6 of the 2TB disks
Replace all 6 of the 2TB disks with new 3TB disks
Factory default
Install new firmware (4.2.28)
Then recreate the rsync task that would copy the old file server over.
Or is there a better order to this. I have looked around and it appears that it is "possible" to mount the 6 disks on a linux machine and recover the data. I am only asking in the case of the primary NAS having a problem prior to getting a clean copy.
It might be better to wait for the firmware upgrade until I have a clean copy (using the 4.2.17 firmware) and then migrate both NAS units one by one.
For future reference, is there any way from the web interface to tell that the operating system partition is filling up?
Thank you for your help!
