elderwolf123
Nov 29, 2018Aspirant
ReadtNAS Duo RND2000v2 Firmware reinstall
I need help, the drives keep initlising and they are good drives, I have tried resetting the NAS and even reinstalling using recovery USB but to no avail. Firmware version wont show up and I have no ...
Nov 29, 2018Guru - Experienced User
What firmware is running on the duo?
What disks are you using?
I suggest that you try powering up the duo with no disks inserted, and check the status with RAIDar. https://kb.netgear.com/20684/ReadyNAS-Downloads
That should detect the NAS and give you a "no disks" status.
- elderwolf123Nov 29, 2018Aspirant
RAIDar does not show what firmware it is running and the drives are both 2TB but I have tried even a 160 gig and nothing. With no drives it shows it in RAIDar but with them in it just initilises and seems to go nowhere even after factory resetting it using inscructions i found on another site for my NAS. The drives I have tried are a 160 Seagate Barracuda 6RAB1DMB, a 2 TB Samsung HD203WI and a 2TB Seagate SV35 W1E0MQX7. When i got the drive at first as I got it second hand there were two 1TB drive which where Seagate and a Samsung but when I tried wiping them it seemed to not initilise again but before wiping it worked with them but I couldnt access the admin panel
- StephenBNov 29, 2018Guru - Experienced User
One question I have is whether you have a Duo v2 or if you have a Duo. The Duo v2 says "Duo v2" on the front panel. A Duo says "Duo" on the front panel, but might have a v2 label somewhere else. RAIDar should also identify the model correctly (with no disks installed).
The boot menu instructions are a bit different for the two models, we can get you to the correct hardware manual once we know for certain what you have.
You might also try wiping the disks again, and try powering up with only one disk installed. That will set up more quickly because there is no RAID syncing that needs to be done.
- elderwolf123Nov 29, 2018AspirantThe front just says ReadyNAS Duo but on the bottom for the model info it says RND2000 v2 so I am not sure. I tried one drive last night, the 160 gig but it didn't seem to work properly
- Jul 15, 2018Retired_Member
