elderwolf123
Nov 29, 2018Aspirant
ReadtNAS Duo RND2000v2 Firmware reinstall
I need help, the drives keep initlising and they are good drives, I have tried resetting the NAS and even reinstalling using recovery USB but to no avail. Firmware version wont show up and I have no ...
elderwolf123
The front just says ReadyNAS Duo but on the bottom for the model info it says RND2000 v2 so I am not sure. I tried one drive last night, the 160 gig but it didn't seem to work properly
Nov 29, 2018Guru - Experienced User
As I said, the Duo might have a v2 label somewhere else. The front is what matters. You have a Duo (v1). Netgear stopped shipping your NAS in Nov 2011. It runs 4.1.x firmware, the most recent (and final) firmware is 4.1.16. https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
One important limitation is that your NAS cannot handle disks that are > 2 TB in size. Another is that it's SMB support is limited to SMB 1.0 (which is being deprecated by Microsoft).
The hardware manual for your Duo is http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
The boot menu is described on pages 15-16.
The software manual is here: http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf
Well, the system should install fairly quickly on a single disk. You might try using one of the 1 TB ones (either zeroing it first, or doing the factory default using the boot menu). RAIDar should detect the NAS after you power up, though there might be a couple of minutes when the Duo is too busy to respond.
After the install, you access the admin web ui with http://nas-ip-address/admin (using the real IP address of the NAS). There will be a security exception you need to click through. The username is admin, the default password is netgear1.
- Jul 15, 2018Retired_Member
