Arteme
Jun 11, 2023Aspirant
Ready DATA 5200 TLS 1.3
Hello community,
Has anyone dealt with this problem before?
We recently migrated our systems to new standards. And now there is the thought of connecting the old NAS drive. I already get the probl...
- Jun 12, 2023
With being late since ReadyDATA OS was EoL in July 2016, there should have been plenty of water flowing down the Rhine river, making it clear that migrating to a supported NAS environment is long time overdue. If you consider to continue to operate these devices in a closed and limited access environment (home, small office, temporary storage, ...) you can certainly do so at your own risk. Nobody else will care about, except if your organization is undergoing mandatory and regular security audits. Even then, you can provide a plan and time window for future actions and continue operations until further advise under an exception plan.
Said that, no fixes or hacks available to my knowledge.
Wonder why you are concerned now, when many other browser environments had stopped supporting these outdated TLS 1.0 and TLS 1.1 years ago already? Be happy that Firefox does still allow to put up an exception.
Grüsse
-Kurt
schumaku
Jun 12, 2023Guru - Experienced User
Grüsse
-Kurt
Arteme
Jun 12, 2023Aspirant
Hello,
Thanks for quick reply, you are absolutely right, it should have happened years ago. I was just hoping there would be a solution for older machines.
It is like it is.
In principle, I have already thought about how I can continue to use it.
Deploying a secure environment and segmenting the network. And probably a computer that has a VPN connection.- SandsharkJun 12, 2023Sensei
Converting the 5200 to ReadyNAS OS6 is an option. That would mean offloading all the data, doing the conversion, and then restoring the data. But with OS6 clearly on it's last legs, moving to an entirely different platform likely makes more sense.
