winger13
Apr 16, 2014Guide
Ready for expansion (RN Pro Pioneer Edition)-Seeking Advice
Hi Everyone. I purchased and setup my Readynas Pro Pioneer around Jan 2010. Aside from one disk issue (increasing errors, which Seagate replaced under warranty) it has been a nice experience. I ...
winger13
Aug 21, 2014Guide
mdgm wrote: Update the firmware if you haven't already. You must be running 4.2.16 or later before you add the 3TB disks.
Add a 3TB disk while the NAS is on. Wait for the resync etc. to complete then add the next disk.
What disks were installed when you last did a factory default?
Note that if your volume capacity was 2.7 TB when you last did a factory default you cannot expand past 10.7 TB
Yes my firmware had been updated.
I bought a brand new diskless RNPE then put in 4 1TB's in XRAID DUAL-REDUNDANCY giving me about 1.8TB capacity. As StephenB mentioned above:
There are two expansion limits
(a)you can't exceed 16 TiB total volume size. That wouldn't apply to you until someone makes > 8 TB drives.
(b) You can't grow a volume more than 8 TiB over its lifetime. If you started with this configuration, you could expand up to 4x5TB. So you have plenty of headroom.
Question. What would have happened if I had went ahead and installed both brand new disks into bays 5&6 while the unit was off and then turn the unit on?
