winger13
Apr 16, 2014Guide
Ready for expansion (RN Pro Pioneer Edition)-Seeking Advice
Hi Everyone. I purchased and setup my Readynas Pro Pioneer around Jan 2010. Aside from one disk issue (increasing errors, which Seagate replaced under warranty) it has been a nice experience. I ...
mdgm-ntgr
Aug 28, 2014NETGEAR Employee Retired
Disc Scrubbing you should consider scheduling to run perhaps every few months or so.
I'd run the Online Filesystem Consistency Check more regularly as this is comparatively fast. Best to run this at a time that you are not writing much to the NAS.
1. Yes you should run both.
2. I don't think so, however you can schedule it to run soon.
3. If there is a problem with the Online Filesystem Consistency Check it may be suggested to run the volume scan on next boot.
As for fixing quotas that is useful if you use quotas (e.g. for users or you use Time Machine) and you are getting errors about not having free space despite having unused quota and free space on the volume.
4. You shouldn't need to run the options in your 3rd question unless there is a problem.
