winger13
Apr 16, 2014Guide
Ready for expansion (RN Pro Pioneer Edition)-Seeking Advice
Hi Everyone. I purchased and setup my Readynas Pro Pioneer around Jan 2010. Aside from one disk issue (increasing errors, which Seagate replaced under warranty) it has been a nice experience. I ...
mdgm-ntgr
Aug 28, 2014NETGEAR Employee Retired
Disk scrubbing does a resync to make sure the disks are still synced sector by sector, that the parity distributed amongst the disks is fixed if there is a problem with it.
It's not going to reduce your error count, that will stay for that disk. However it will make sure the disks are in sync.
It runs an online read-only filesystem check to see if there are issues with the filesystem (e.g. with the files or directories on there). If there are issues then the offline volume check may help but you might wish to ask support about that first if the need arises.
