leotchest
Feb 08, 2016Aspirant
Ready NAS 102 impossibly slow
I have had the NAS 102 for couple of years now and it seemed to work OK - in fact i mainly just use it as an external backup device. I have all my files and folders stored on it. Typically, I would...
- Feb 08, 2016
Which services and apps are you running?
Are you using the anti-virus service? If so, please disable it under System > Settings > Services.Can you send me your logs (see the Sending Logs link in my sig)?
Welcome to the Community!
bolek007
Feb 08, 2016Tutor
hi, the same issue (RN102) I have after upgrade fw from 6.4.0 to 6.4.1 , or 6.4.2 . Downgrade to 6.4.0 fw solved this issue for me...
- JennCFeb 09, 2016NETGEAR Employee Retired
Hello bolek007,
Was the AntiVirus already disabled before downgrading FW and it was already using 6.4.2?
