leotchest
Feb 08, 2016Aspirant
Ready NAS 102 impossibly slow
I have had the NAS 102 for couple of years now and it seemed to work OK - in fact i mainly just use it as an external backup device. I have all my files and folders stored on it. Typically, I would...
- Feb 08, 2016
Which services and apps are you running?
Are you using the anti-virus service? If so, please disable it under System > Settings > Services.Can you send me your logs (see the Sending Logs link in my sig)?
Welcome to the Community!
bolek007
Feb 08, 2016Tutor
hi, the same issue (RN102) I have after upgrade fw from 6.4.0 to 6.4.1 , or 6.4.2 . Downgrade to 6.4.0 fw solved this issue for me...
JennC
Feb 09, 2016NETGEAR Employee Retired
Hello bolek007,
Was the AntiVirus already disabled before downgrading FW and it was already using 6.4.2?
- bolek007Feb 09, 2016Tutor
Hello JennC,
Antivirus was all the time enabled... Now I am back on 6.4.0
- StephenBFeb 09, 2016Guru - Experienced User
bolek007 wrote:
Hello JennC,
Disabling AntiVirus would also have restored your performance.
yes, I can confirm, with disabling AntiVirus is performance on 6.4.2 ok, thanks...
