DoctorBrown
Nov 14, 2022Apprentice
Ready NAS 102, What is the maximum throughput possible with this NAS?
I know this subject has been discussed before, but I haven't found a posting that really answers the question. I realize there are many, many factors that affect what one actually achieves but I woul...
DoctorBrown
Dec 14, 2022Apprentice
More new data.
From a second Windows 10 system the throughput is the same at 15MB/s.
I ran a test on my Macbook Pro. Verified that I was running SMB3 on the MacOS. I then disabled AFP on the RN102 to make the Mac use SMB. Then copied my test files. When I first tried this the transfer started out about 25 MB/s then dropped to 6-8MB/s. Later, I was able to transfer the whole 1 GB file at 25 MB/s write and 50 MB/s read using SMB. ( I don't know why it changed)
That leaves the conclusion that my Windows system is part of the cause.
Any ideas what to check next?
Dec 15, 2022Guru - Experienced User
Perhaps also try using NFS on the synology, just to confirm the issue is limited to SMB?
Have you tried changing the transport encryption and the strict sync settings?
