Triteleaf
Jan 24, 2016Aspirant
Ready NAS 104 Locks Up (6.4.1)
Hello all! At some point that I haven't nailed down, my ReadyNas104 (6.4.1) hangs completely. All front lights get stuck solid, the screen continues displaying whatever was on it at the time of t...
- Jan 24, 2016
Thanks for the logs. Please try ReadyNASOS 6.4.2 (RC1)
There is a known RAID-5 issue you may be running into.
Looking at your logs also it looks like you still have anti-virus enabled.
Can you see if the system still locks up if anti-virus is disabled and you update to 6.4.2-RC1?Welcome to the Community!
Triteleaf
Jan 26, 2016Aspirant
Well, The new firmware is in, and there hasn't been a lockup, so I'll assume the issue is solved.
The volume resync seems to be taking longer than normal, but at least it's making progress.
stijnpeeters
Feb 01, 2016Aspirant
I didn't have AV on and still my nas locked up at FW 6.4.1
- BrianL2Feb 01, 2016NETGEAR Employee Retired
Hi stijnpeeters,
Welcome to the community!
Kindly send us a copy of your device logs and try the same RC Firmware (Beta) in your unit. Then tell us if there's still a lock-up issue.
Kind regards,
BrianL
NETGEAR Community Team
