HuwSy
Feb 05, 2023Guide
Ready Nas 516 drive sleep issues with readynasd
Hi Im a new Readynas user, just as they are retired and because my work decided to throw the 516 unit out with 5x 2TB drives included because they didn’t have the required support going forward. It...
HuwSy
Feb 06, 2023Guide
Hi
Yes it’s 10.6.8. I have to fire up the service again to check versions.
I have disabled ipv6 just now and enabled block dump, will let it settle a little and see what it’s like later this afternoon. If all of this was just ipv6 then it will be slightly annoying but I think I have nicely tuned the disc usage down for what will be a system that spends most off its time completely idle in my case.
Thanks
Thanks
HuwSy
Feb 07, 2023Guide
Disabling ipv6 on both nics made no difference and additional logging only shows enclosure monitor repeatedly dirtying and writing nodes which is nothing new from my findings with iotop. I still don’t know which files it’s hitting to move to cache though.
Although I have now taken the alternate route and setup msmtprc and mdadm to email and shutdown on failure and will use the nas without readynasd or apache2 or samba which are the biggest culprits, although it does reduce the attack surface given I can’t really update the Debian base here.
Or could I update Debian if I am not using more and more of Netgear software here?
