gronaix
Aug 09, 2019Tutor
Readynasd not starting after creating /.force_snapshots_upgrade
Hello!
On my ReadyNAS I face currently the following issue, that the readynasd service is not starting. Therefore my access to the admin page is not available.
Background: within upgrading to current ReadyNASOS 6.10.1 created snapshots haven't been able to delete via the webinterface. I resolve this, I followed the suggestions in this topic but it did not help in my situation.
After creating the .force_snapshot_upgrade file with the commands below, my readynasd.service doesn't come back to live:
# touch /.force_snapshots_upgrade # systemctl restart readynasd
It will give the following output in systemd when trying to restart and keeps it in a loop:
Aug 09 21:13:34 WG-LAN systemd[1]: Starting ReadyNAS System Daemon... Aug 09 21:13:34 WG-LAN readynasd[32148]: readynasd log started Aug 09 21:13:34 WG-LAN readynasd[32148]: readynasd started. (restarted=0) Aug 09 21:13:34 WG-LAN readynasd[32148]: DB (main) schema version: 24 ==> 24 Aug 09 21:13:35 WG-LAN readynasd[32148]: DB (queue) schema version: new ==> 0 Aug 09 21:13:36 WG-LAN readynasd[32148]: Failed to insert into $timemachine_quota table Aug 09 21:13:36 WG-LAN readynasd[32148]: _rndb_update_timemachine_user() ==> 3 (2ms) Aug 09 21:13:36 WG-LAN readynasd[32148]: rndb_account_import() ==> 3 (813ms) Aug 09 21:13:36 WG-LAN readynasd[32148]: rndb_import() ==> 3 (1381ms) Aug 09 21:13:36 WG-LAN readynasd[32148]: Error rndb_import() ==> rc=3 Aug 09 21:13:36 WG-LAN readynasd[32148]: dba import failed Aug 09 21:13:36 WG-LAN systemd[1]: readynasd.service: Main process exited, code=exited, status=255/n/a Aug 09 21:13:36 WG-LAN systemd[1]: Failed to start ReadyNAS System Daemon. Aug 09 21:13:36 WG-LAN systemd[1]: readynasd.service: Unit entered failed state. Aug 09 21:13:36 WG-LAN systemd[1]: readynasd.service: Failed with result 'exit-code'. Aug 09 21:13:36 WG-LAN systemd[1]: readynasd.service: Service hold-off time over, scheduling restart. Aug 09 21:13:36 WG-LAN systemd[1]: Stopped ReadyNAS System Daemon.
All research in this board and through the web doesn't brought up a solution, particularly the part regarding the failed DB insert seems to be not posted anywhere else.
To fix it myself, I tried to restore several database backups I found in /var/backups/readynas but the outcome remains the same. Even deleting the whole db.sq3 in /var/readynas doesn't startup the daemon.
Meanwhile in getting desperate with the issue, I was able to solve the initial problem and removed the snapshot with the command below
brtfs subvolume delete <path>
Is there any solution available to either
- disable the timemachine_quota input at daemon start
- reset/sanitize the database so the input will work
- restore a backup via SSH/Commandline to initial state before my changes
Some META information which might be required:
# cat /etc/os_version ReadyNASOS!!version=6.10.1,time=1557877821,arch=arm,descr=ReadyNASOS
# sqlite3 /var/readynasd/db.sq3 "PRAGMA integrity_check" ok
Best regards,
gronAix
Hi,
will consider reinstalling when I have physical acces to the ReadyNAS. Currently I am trying to fix it from about 1500 km away :)
Here are the requested outputs:
Database
root@WG-LAN:~# sqlite3 --header --column /var/readynasd/db.sq3 'select * from "$timemachine_quota"' user_id enabled capacity_mb ---------- ---------- ----------- 110 1 5000 111 1 5000
Timemachine config
root@WG-LAN:~# cat /etc/netatalk/timemachine.conf # DO NOT EDIT. [MaxTv's timemachine] path = /SERIEN/.timemachine/MaxTv rwlist = MaxTv valid users = MaxTv invalid users = guest nobody @guest @nogroup vol size limit = 4768 time machine = yes [admin2's timemachine] path = /SERIEN/.timemachine/admin2 rwlist = admin2 valid users = admin2 invalid users = guest nobody @guest @nogroup vol size limit = 4768 time machine = yes
Start with debug log-level
root@WG-LAN:~# readynasd -v 5 -l - [19/08/12 21:01:48] 32056:32056 readynasd.c:1040 () readynasd log started [19/08/12 21:01:51] 32056:32056 context.c:239 (debug) NEW GLOBAL_CONTEXT: db.sq3=0xc3d118 [19/08/12 21:01:51] 32056:32056 context.c:286 (debug) NEW GLOBAL_CONTEXT: event.sq3=0xc41128 [19/08/12 21:01:51] 32056:32056 context.c:289 (debug) NEW GLOBAL_CONTEXT: globalctx=0xc3cdb8 [19/08/12 21:01:51] 32056:32056 readynasd.c:1299 () readynasd started. (restarted=0) [19/08/12 21:01:53] 32056:32056 db_access.c:127 (error) Error rndb_import() ==> rc=3 [19/08/12 21:01:53] 32056:32056 readynasd.c:1358 (error) dba import failed
As stated before, I already manually removed the btrfs subvolumes. Can this cause issues with the timemachine configuration?
I tried now to fiddle around with the timemachine.conf (haven't found this file before) and replaced it with an empty file with same access rights and the webinterface is now accessible again. For now it is fine to me, but reinstalling the device is still something to consider.
It sounds like you are able to access it with ssh. Have you tried simply deleting .force_snapshots_upgrade?
You might also try an OS reinstall.
- gronaixTutor
Hi StephenB,
I deleted the /.force_snapshots_upgrade already, but it'll still run into the issue described above.
Will it be safe for the stored Data to reinstall the OS?
gronaix wrote:Will it be safe for the stored Data to reinstall the OS?
It should be (it's designed to be non-destructive). Though it is always a good idea to have a backup.
In addition to partially reinstalling the OS, it will
- reset the admin password to password
- reset the network configuration to use DHCP with no bonding
- turn off volume quota
The procedure is documented on pages 28-29 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
