HuwSy
Feb 05, 2023Guide
Ready Nas 516 drive sleep issues with readynasd
Hi Im a new Readynas user, just as they are retired and because my work decided to throw the 516 unit out with 5x 2TB drives included because they didn’t have the required support going forward. It...
HuwSy
Mar 18, 2023Guide
Hi
I had previously tried this with a factory reset but experienced the same issues. I did notice the network connected, ip would pop up on display at random intervals but probably only every few hours not as often as the drive spin up. I have only 1 of the 2 NICs connected and the 2nd disabled in the web interface. Does this need or attempted both interfaces perhaps? If so I’ll need to disable or run another line as the rest of the network is already slower than this unit.
Thanks
Thanks
NiveditaP
Apr 06, 2023NETGEAR Employee Retired
Hello HuwSy
Factory Default and OS reinstall are different.
Could you please perform OS reinstall once and check again ?
Have a lovely day,
NiveditaPa
Netgear Team
- SandsharkApr 06, 2023Sensei
Factory Default is more than an OS Re-install. If a default didn't fix it, an OS re-install certainly won't. After the default, did you restore a saved configuration that may have restored the problem? Did you install any apps or enable ReadyCloud?
