netkid1
Dec 31, 2019Initiate
Ready NAS Build in Home Folders Backup
Hi, I am using OS 6 Firmware 6.10.2 and I would like to be able to use the backup functionality to backup individual folders in my home folder to different locations. However, when I try to create a ...
netkid1
Jan 05, 2020Initiate
StephenB wrote:
netkid1 wrote:Hi, I am using OS 6 Firmware 6.10.2 and I would like to be able to use the backup functionality to backup individual folders in my home folder to different locations. However, when I try to create a backup job it does not allow me to drill down further into the user home folder to select individual folders within the users folder.
What are the backup destinations? (USB drives on attached to the same NAS, a second NAS, ???)
xStephenB Its another NAS and I am able to connect to that Nas. I just want to be able to selectively choose the source folder instead of backing up the entire home directory. Thx
Jan 05, 2020Guru - Experienced User
Have you tried running the backup on the destination NAS, and entering the full folder path as the source?
