jyokom
Aug 21, 2011Aspirant
Ready NAS Duo stuck.
I recently lost power. when I turned the ReadyNAS back on, it hangs up. The green power LED is three short flashes with one long. then the activity led flashes once. the disk 2 led is a constant flash...
jyokom
Aug 31, 2011Aspirant
Finally talked with a technical Engineer. Although it wasn't indicating a bad drive, the solution was as follows. Take each drive out individually and reboot each time. The device wouldn't boot or allow a flash install with the drive in bay 1. All worked as advertised with the drive in bay 2 although all data was lost. We reinserted the original drive to bay 1 and it is currently syncing. At this point I'm not sure if it contains the original data. I do have a backup so all is not lost. This system and the network server are now both on a UPS.
