Rob_M
Apr 14, 2022Aspirant
Ready NAS Duo v2 -- Installation problems
Hello, everyone. I have a specific use for my trusty old Ready NAS Duo v2 which was last used about 9 years ago. It ran very well for years with no issues at all before 'retiring' it. I did the o...
- Apr 24, 2022
Thanks once again for all your help, Steven.
I think I'll manage from here.
Kind regards,
Rob.
Apr 16, 2022Guru - Experienced User
Rob_M wrote:
Secure Connection Failed
An error occurred during a connection to 192.168.0.17. Peer using unsupported version of security protocol.
Error code: SSL_ERROR_UNSUPPORTED_VERSION
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the web site owners to inform them of this problem.This web site might not support the TLS 1.2 protocol, which is the minimum version supported by Firefox.
I can see that I'll need to look more into TLS and will let you know how I get on.
I've already linked in the relevant thread on this topic - https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER-MISMATCH-problem-for/m-p/2198243
Your NAS only supports TLS 1.0 - which is outdated, and recently browsers began dropping support for it. You can still use IE, or Edge (in IE mode). Or you can install an old browser, and immediately reconfigure it so it won't autoupdate. Firefox 94.0.2 will work (likely some later ones also).
You can also go in with ssh, and make a simple mod to virtual.conf to prevent redirection to https. That will let you log in with http using any browser. Of course that link is unencrypted.
Rob_M
Apr 24, 2022Aspirant
Kind regards,
Rob.
