Madaxus
Jun 24, 2018Aspirant
Ready NAS Duo v2 - dont see model and firmware in RAIDair
Hello,
I have huge problem with my ReadyNAS Duo v2. Everytime when i turn it on everything looks fine, but when i try to find it in my network by using RAIDar it is visable without and model and fi...
- Jun 24, 2018That screenshot shows “No Disks Detected”. If the disks are fine that suggests a hardware issue with the chassis, not a problem on the internal flash.
It’s normal for it to not show the model when in the “No Disks Detected” error state.
mdgm-ntgr
Jun 24, 2018NETGEAR Employee Retired
Madaxus
Jun 25, 2018Aspirant
Hello mdgm,
Thank you for your answer. I was almost 100% sure it does not depends on disks hmm... I will try with two new disks today evening and check it again.
- MadaxusJun 26, 2018Aspirant
That was exacly HDDs. I was sure that the system files arent located on HDDs. I guess its solved, with new hdds everything works fine :)
Thanks again for your support.
