Madaxus
Jun 24, 2018Aspirant
Ready NAS Duo v2 - dont see model and firmware in RAIDair
Hello,
I have huge problem with my ReadyNAS Duo v2. Everytime when i turn it on everything looks fine, but when i try to find it in my network by using RAIDar it is visable without and model and fi...
- Jun 24, 2018That screenshot shows “No Disks Detected”. If the disks are fine that suggests a hardware issue with the chassis, not a problem on the internal flash.
It’s normal for it to not show the model when in the “No Disks Detected” error state.
Madaxus
Jun 25, 2018Aspirant
Hello mdgm,
Thank you for your answer. I was almost 100% sure it does not depends on disks hmm... I will try with two new disks today evening and check it again.
Madaxus
Jun 26, 2018Aspirant
That was exacly HDDs. I was sure that the system files arent located on HDDs. I guess its solved, with new hdds everything works fine :)
Thanks again for your support.
