RobertKaiser
Mar 07, 2018Aspirant
Ready NAS Duo v2 - LED blinkt RAIDar findet NAS nicht
Liebe Community, Vielleicht kann mir jemand weiterhelfen. Nach einem Stromausfall zeigt sich folgendes Verhalten nach dem NAS-Hochlauf. Die LED über dem backup Knopf blinkt und der Lüfter dreht seh...
- Mar 12, 2018
I'm glad you got the data off the disks. Try powering up the NAS without the disks, and see if RAIDar can find it.
It should discover it, and report a "no disks" status.
If that fails, there is likely something wrong with the chassis (though there's a chance it's the power brick).
If it succeeds, then a factory default is the right next step.
Mar 07, 2018Guru - Experienced User
Try powering down the NAS and removing the disks (labeling by slot). Then power it up, and see if RAIDar finds it. It should discover it, and give you a "no disks" status.
RobertKaiser
Mar 08, 2018Aspirant
Thank you for your fast reply, I will try it. If this works is it then possible to insert the disks again without any data loss?
