RobertKaiser
Mar 07, 2018Aspirant
Ready NAS Duo v2 - LED blinkt RAIDar findet NAS nicht
Liebe Community, Vielleicht kann mir jemand weiterhelfen. Nach einem Stromausfall zeigt sich folgendes Verhalten nach dem NAS-Hochlauf. Die LED über dem backup Knopf blinkt und der Lüfter dreht seh...
- Mar 12, 2018
I'm glad you got the data off the disks. Try powering up the NAS without the disks, and see if RAIDar can find it.
It should discover it, and report a "no disks" status.
If that fails, there is likely something wrong with the chassis (though there's a chance it's the power brick).
If it succeeds, then a factory default is the right next step.
RobertKaiser
Mar 08, 2018Aspirant
Thank you for your fast reply, I will try it. If this works is it then possible to insert the disks again without any data loss?
Mar 08, 2018Guru - Experienced User
Do you know what firmware your NAS is running (it's either 4.1.x or 5.3.x)?
Also are you using the default XRAID (RAID-1)?
If it works, the problem is with the disks, and not the NAS chassis. If it fails, then you need a new NAS.
If it is the disks, then it could be that
- one (or both) disks were damaged when the power failed.
- there was some file system corruption because pending writes in the NAS cache were lost.
I think the best approach for data extraction (assuming XRAID/RAID-1) is to connect drive 1 to a Windows PC (either with SATA or a USB dock), and see if R-linux for Windows sees the data volume. If it does, then offload it to a USB or internal drive on the PC. http://www.r-tt.com/free_linux_recovery/
- RobertKaiserMar 08, 2018Aspirant
Hi Stephen,
Thank you for your help.
I removed both disks and tried the startup and it fails. It is the same behaviour: constant blinking led and RAIDar does not find the NAS. So this is now the point where I need a new NAS?
Regarding the firmware version: I am not completely sure but I think it is the older version.
regards,
Robert
- StephenBMar 08, 2018Guru - Experienced User
Yes, RAIDar not finding it suggests the chassis has failed. The only other possibility would be something wrong with the power brick.
Note there would be a flashing led pattern though I don't think you are seeing the "no disks detected" pattern.
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
4.1.x is a v1. The labeling is confusing.
The v2 (arm CPU) says v2 on the front panel, runs 5.3.x firmware and has a -200XXX at the end of the part number. The XXX might be NAS, or it might be a country-specific code.
A v1 runs 4.1.x firmware, and has a -100XXX at the end of the part number. It often has a label on the back that says v2.
Anyway, the current ReadyNAS equivalent is the RN212. It is much faster than your duo, and has more features. You can't directly migrate the disks though, you'll need to extract the data as I described above.
- RobertKaiserMar 12, 2018Aspirant
Hi Stephen,
Sorry for the late reply I was busy with the restore.
I had a closer look to the part number and it is RND2000-200EUS.So the firmware version should be 5.3.x but I can't check.
I tried to find out together with my daugther the error code but there is immediately the blinking backup led. We couldn't see any blinking error code. Do you think a restart with the factory defaults may work?
Over the weekend I have extracted all data and I am happy about that.
Thank you for your help and the hint with RLinux.
