gerritreijnders
Jan 12, 2022Aspirant
Ready nas NV+ booting problem HDD?
Hi, I have a readynas NV+,with 4 HDDs of 2TB. Suddenly I couldn't access my files anymore. Did a reset but it hangs on booting. It also failed to get to the front page via Raidar. I bought a 2nd ha...
- Jan 20, 2022
Problem solved.
hooked up 3 HDD to a desktop ComputerWith recovery software, it could find all maps. 5,4TB
and it was all possible to recover.
Jan 13, 2022Guru - Experienced User
Unfortunately, you have learned that RAID isn't enough to keep your data safe. Hopefully you can get it back, and then put a backup plan in place.
gerritreijnders wrote:Did a reset but it hangs on booting. It also failed to get to the front page via Raidar.
What kind of reset? A factory default (sometimes called factory reset) is destructive.
Can you connect the disks to a Windows PC (either with SATA or a USB adapter/dock)? If so, try testing them with vendor tools - Seatools for Seagate, WD's Dashboard for WDC. Run the long generic test on each (which will take a couple hours).
gerritreijnders
Jan 13, 2022Aspirant
i hold the reset button power button for 5 seconds the leds go on.OS
I did a memory test but thats ok.
Now they are in the NAS almost a day, booting ...
led 123 are on
led 4 is blinking
Power button, first blinking, now solid blue.
Raidar
Status, system is starting
IP adres 192.168.168.168
Else i cant do nothing with Raidar
All HDD are the same WD20EARX 2TB
The test i will try.
Thanks so far.
