hypatia
Mar 18, 2016Aspirant
Ready NAS NVX Power failure
I have a 2010 bought ReadyNAS NVX which will no longer power up (not a flicker or glimmer of any life). I have tried: - changing cables - changing power socket - leaving cold for 24 hours and res...
- Sep 01, 2016
Just to close this off, in my case it definately needed a new power supply. I replaced it myself with one from ebay, advertised for the ReadyNas. With shipping it was around $100, but didn't require any repinning or changing. I disassembled the NVX and re-assembled with the replacement power supply and the NAS picked up where it left off.
omicron_persei8
Jul 24, 2016Luminary
Hi,
An NVX is x86 architecture while NV and NV+ are SPARC. So you cannot put the HDDs of the NVX into an NV+. But, the power supply is the same. So it is possible to put the PSU of an NV+ into an NVX chassis.
Alternatively, you can buy an RN314. As the architecture is also x86, you can boot the unit with your drives in it and it will work (as long as your drives are ok of course).
