hypatia
Mar 18, 2016Aspirant
Ready NAS NVX Power failure
I have a 2010 bought ReadyNAS NVX which will no longer power up (not a flicker or glimmer of any life). I have tried: - changing cables - changing power socket - leaving cold for 24 hours and res...
- Sep 01, 2016
Just to close this off, in my case it definately needed a new power supply. I replaced it myself with one from ebay, advertised for the ReadyNas. With shipping it was around $100, but didn't require any repinning or changing. I disassembled the NVX and re-assembled with the replacement power supply and the NAS picked up where it left off.
omicron_persei8
Jul 24, 2016Luminary
RNDU4000 (Ultra 4), RNDP4000 (Pro 4) will also work, but they're the same generation as the RNDX400E (NVX). RN314 is the new one.
- cathcamJul 24, 2016Guide
Thanks so much for the prompt reply.
Do you mean the drives will work in them as they are also Intel based ? And/or the power supplies would work in the NVX?
Having had this failure, I'm interested in getting a backup NAS. So conceptually getting a different unit I can put the drives in, and then buying a newer model or power supply to revive the old model would be interesting.I have a simple, single user set-up, the NAS is used mostly for music and a Logitech Squeezebox music server.
Is the RND4000 compatibe? It doesn't have a letter ...
