Tim-dk
Sep 07, 2018Aspirant
Ready NAS Pro no power
I have a Ready NAS Pro model RNDP6620-100NAS, it won't power on, I've removed and reinserted the disks, it didn't help. I read you could replace the PSU but I'm not sure which model I would get. Any ...
Marc_V
Sep 09, 2018NETGEAR Employee Retired
Hi Tim-dk
Welcome to the Community!
This old thread might help. Says there that you may need 24 pin extender and 3 4-pin molex connectors.
Model mentioned was a SeaSonic SS-300SFD or something that might be similar today in the market.
Hope this helps!
Regards
- Tim-dkSep 09, 2018AspirantI try to see if that works. Thanks.
- SandsharkSep 10, 2018Sensei
If you have a standard ATX supply, you can wire that up externally and see if it fixes it before you buy a new supply. But the supply is the most likely cause. The original Seasonic is no longer available, but there are other SFX supplies that will work. Having the three 4-pin Molex "hard drive" connections is the difficult thing to find.
