Orbi WiFi 7 RBE973
Reply
Spare ReadyNAS Pro 6 Power Supply
steveoelliott
Luminary
Hi all,
One of my customers is looking to aquire a spare power supply unit for their two Pro 6 models... They are 3.5 and 2.5 years old respectively and whilst they are still under hardware warranty, they would like to have a spare power supply unit on site should the worst happen...
I seem to recall that Netgear don't supply the power supply seperately and in the event of a failure just ship a new chassis.
Thanks...
Message 1 of 8
Accepted Solutions
Guru
Re: Spare ReadyNAS Pro 6 Power Supply
A 4" atx extender should be enough (based on other poster's comments).  A fairly new thread on this topic is here: https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/ReadyNAS-Pro-Replace-CPU-Fan/td-p/9...
Message 4 of 8
All Replies
Guru
They use sfx supplies.  Look for a SeaSonic SS-300SFD.
You might need a 24 pin extender - you might as well get them while you are at it.
Also, you need 3 4-pin molex connectors.  If the supply doesn't have 3, you might also need an SATA to molex adapter.
Message 2 of 8
steveoelliott
Luminary
Thanks... Is there not a way to procure the correct PSU with the custom length connector and correct number of molex? Otherwise I can go ahead and buy one but any ideas on the length extension needed?
Message 3 of 8
Guru
Message 4 of 8
steveoelliott
Luminary
Yes, really useful post that.
Do the molex connectors on the drive board feature a cap so you can easily re-wire? I asked that of the poster too.
Message 5 of 8
Sandshark
Sensei
The Molex connectors on both I have replaced were easily moved from the original supply to the replacement.  Of course, doing so viods the warranty on the supply.  But I found it much cleaner to use the right-angle ones from the original supply and cut the cable length down.
Message 6 of 8
steveoelliott
Luminary
OK Thanks... Are any special tools needed to make the connectors up, other than some wire cutters of course.
Message 7 of 8
Sandshark
Sensei
Nope, they are the kind that you just press the wire into.  There are plastic tools meant for it if you do it all the time, but a small flat screwdriver will work well enough.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 10429 views
  • 0 kudos
  • 3 in conversation
Announcements
