Tim-dk
Sep 07, 2018Aspirant
Ready NAS Pro no power
I have a Ready NAS Pro model RNDP6620-100NAS, it won't power on, I've removed and reinserted the disks, it didn't help. I read you could replace the PSU but I'm not sure which model I would get. Any ...
Tim-dk
Sep 09, 2018Aspirant
I try to see if that works. Thanks.
Sandshark
Sep 10, 2018Sensei
If you have a standard ATX supply, you can wire that up externally and see if it fixes it before you buy a new supply. But the supply is the most likely cause. The original Seasonic is no longer available, but there are other SFX supplies that will work. Having the three 4-pin Molex "hard drive" connections is the difficult thing to find.
