NC7U
May 28, 2019Follower
Ready NAS RN102 GUI Missing
Firmware is the latest. Can access via ssh. Long story short! Using ssh with a terminal (linux) thought I was connected to a Raspbery Pi - removed apache2. What I did not realize is that I was actua...
- May 29, 2019
Sandshark wrote:
The re-install will also set your admin password back to "password" and IP assignment to DHCP (if you happen to currently have it set to static).
It also will turn off quota on the volume settings wheel. So if you had that enabled, you'll need to turn it on again.
Sandshark
May 28, 2019Sensei
OS re-install does not do anyting to your data. Just make sure that's what you do, not a factory default. The re-install will also set your admin password back to "password" and IP assignment to DHCP (if you happen to currently have it set to static).
May 29, 2019Guru - Experienced User
