FirstSon
Dec 08, 2021Aspirant
Ready NAS Ultra 2 does not turn on
I haven't had a NAS in use for about a year. Recently I decided to start it up again. I installed new disks in it and turned it on. Everything worked fine for about an hour. After that, the NAS just ...
Sandshark
Dec 08, 2021Sensei
Schematics are not available.
- FirstSonDec 08, 2021Aspirant
Okay. Perhaps someone has experienced a similar problem and knows where to look for the answer
- SandsharkDec 09, 2021Sensei
You can try a different power brick, but iot really doesn't sound like that's it. I have a Pro2 (same hardware except the processor) with an internal 12V regulator that can only handle spinning up one drive. I didn't find anything promising to try to fix it.
- FirstSonDec 09, 2021Aspirant
The repairman used his own, lab-grade power supply with 6 amps. It's not the power supply. There is clearly a short on the board. But without a schematic of the motherboard it is not clear where to look for it
