FirstSon
Dec 08, 2021Aspirant
Ready NAS Ultra 2 does not turn on
I haven't had a NAS in use for about a year. Recently I decided to start it up again. I installed new disks in it and turned it on. Everything worked fine for about an hour. After that, the NAS just ...
Sandshark
Dec 08, 2021Sensei
Schematics are not available.
FirstSon
Okay. Perhaps someone has experienced a similar problem and knows where to look for the answer
- SandsharkDec 09, 2021Sensei
You can try a different power brick, but iot really doesn't sound like that's it. I have a Pro2 (same hardware except the processor) with an internal 12V regulator that can only handle spinning up one drive. I didn't find anything promising to try to fix it.
- FirstSonDec 09, 2021Aspirant
The repairman used his own, lab-grade power supply with 6 amps. It's not the power supply. There is clearly a short on the board. But without a schematic of the motherboard it is not clear where to look for it
- MCEComputersDec 09, 2021Apprentice
I had similar symptoms with my Ultra 2 a while back, although I never had anyone check voltages or such.
I found it turned off one morning and every time I turned it back on, it would run for about 10-20 seconds and shut back down.
When I opened up the case I found that two of the plastic pins holding the heatsink down on the cpu had snapped so the heatsink was not contacting the cpu. I replaced all four of the plastic hold downs with some 6/32 nylon screws/nuts and that fixed things.
Not sure if this applies to your situation, but it may be worth checking. Overheated cpus can do all kinds of bad things.
