SpeedyGeek
Jan 12, 2017Tutor
Ready NAS Ultra 2 power supply issue and out of support
Hi all, I have a readynas ultra 2 which I purchased in 2011. Looking at the support site this is now EOL: https://www.netgear.com/support/product/RNDU2000%20%28ReadyNAS%20Ultra%202%29.aspx It...
- Jan 30, 2017
I didnt mention it on the previous post because I wasnt sure if it was significant or not, but I "hoovered" out by NAS as well just before putting the second dsik back in.
So maybe we have the cause of the problem ... DUST !!!
Thanks for all your help on this one. :smileyhappy:
marsh_66
Jan 29, 2017Initiate
I had similar problem on my Ultra 2 Plus running fine on unsupported OS 6.5.2 .
I suddenely started to get these V+12 messages and numerous HD resync occurences after power downs . I swapped out the PSU brick for a similar one albiet a slight increase in grunt - 5.5 amp capable . However this had no effect . I then took the complete chassis apart including all daughter boards which was surpisingly easy . I then blasted everything with compressed air to remove a fair amount of dust .
Put it all back together and system now back to normality ( touch wood ) with no more of these reports after a week . Perhaps 3 years of dust effected the sensor - dunno , but seems to have worked for me .
- SpeedyGeekJan 30, 2017Tutor
