Vez
Dec 29, 2017Aspirant
Ready NAS Ultra 4 plus slow write speed
My write speed from my PC is extremely slow, it appears to start off at the expected 100mbps per second, and then drops to single digits within seconds..... I read that 6.9.1 fixed "interface tim...
Dec 29, 2017Guru - Experienced User
Is the PC using wireless or ethernet? You say "100 mbps" - do you really mean megabytes per second?
If you are using bonding, the try testing without the bond. Also, if you are using jumbo frames, try disabling them.
Also, if you are using a Windows PC, can you try testing with NAStester? http://www.808.dk/?code-csharp-nas-performance
- VezDec 29, 2017Aspirant
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on X: 5 times...
Iteration 1: 9.91 MB/sec
Iteration 2: 7.56 MB/sec
Iteration 3: 9.28 MB/sec
Iteration 4: 54.40 MB/sec
Iteration 5: 19.33 MB/sec
Average (W): 20.09 MB/sec
Running a 400MB file read on X: 5 times...
Iteration 1: 97.96 MB/sec
Iteration 2: 104.32 MB/sec
Iteration 3: 98.37 MB/secAs said previously with Teaming enabled on the switch and NAS it has worked flawlessly until 6.9.0. I will get an "unteamed" to follow.
and yes I did mean 100MBs.
Okay, looks as though I hadn't set the teaming back to mode 3+4 (which is was prior to 6.9.0) - set to 2+3 as this gave the best performance on 6.9.0.
I have now changed it back to 3+4 on 6.9.1 (prior to single NIC testing), and everything now seems to be normal with regard write speed :)
Thanks for your assistance :) (presently writing a 10gb file near on 100MBs - which I wasnt able to do this morning).
- VezJan 02, 2018Aspirant
Right further more, I did a quick test this morning and the expected behavour of the fault appears to be back, strange how it was fine after switching mode but non the less, for example, here is the file transfer from a test file:
Starts off fine then drop to single digits as per earlier post. I will have to get a test done where it isn't using a teamed NIC.
