racer841
Apr 24, 2020Aspirant
ReadyCloud security issues
Hi. I decided to try ReadyCloud with my RN104. So I started ReadyCloud service on device, connected device to my account and right after I was able to see device content on web and mobile. But: ...
racer841
May 14, 2020Aspirant
Hi.
Thanks for the answer, but I can't agree. I've just connected to my NAS from corporate network, where no NETGEAR home routers are in use. The connection to my NAS through readycloud.netgear.com is still insecure (http://readycloud.netgear.com).
Regarding the issue#2, no, I was not able to download files after I've disabled ReadyCLOUD on the NAS.
Greg
Sandshark
May 14, 2020Sensei
You misread the response. ReadyCloud is also included on some Netgear home routers, and this restriction is based on what they need to make it work. That you don't have a Netgear home router has nothing to do with it, and the rest of the response explains why you shouold have no concern.
But, frankly, I don't understand why you would use ReadyCloud in that environment. It's intended as a home solution, A corporate network would more likely be using a VPN.
- racer841May 14, 2020Aspirant
I don't use ReadyCloud in corporate environment. RN 104 is my home NAS and I just tried to connect it from internet - in this case corporate network.
So I've NAS at home, beyond two routers - one is my private orbi and the second is router from my ISP. None of routers allows any direct connection to my home network, so I think NAS connects to readycloud. Readycloud allowes authenticated user/connection to see NAS content from internet, but the connection is to readycloud, not to NAS directly. Why this internet --> readycloud connection is not secured, just as readycloud login page is?
- StephenBMay 15, 2020Guru - Experienced User
If all you want is remote access for yourself, then I suggest that you set up OpenVPN on the Orbi (and forward the ports it needs in your ISP router). That's what I do myself (I need to use my Fios router at the edge, and have an Orbi router right behing it).
Like schumaku I am also unclear as to exactly how the web interface to readycloud is secured (though I am not doubting JohnCM_S ).
But overall, I prefer using OpenVPN for simple remote access. There's no reason I need to connect via a cloud service for that.
- racer841May 15, 2020Aspirant
I tought about out of the box solution that would give me access to private stuff from both web and mobile, just as i.e. NextCloud. ReadyCloud seemed to be good candidate, now I think my doubts were justified.
