markvalpreda
Sep 27, 2019Aspirant
ReadyDATA 5200 - unable to start/stop/remove replication
Have a ReadyDATA 5200 with replications set up and not working....but I cannot get rid of them. The Start/Stop/Disable/Delete buttons are all greyed out. Is there a way to manually clear these out? I...
JohnCM_S
Oct 02, 2019NETGEAR Employee Retired
Hi markvalpreda,
Are you referring to the Local Replicate or are you using the Replicate web site?
If you are using the Local Replicate, may I know also the Replication status?
markvalpreda
Oct 02, 2019Aspirant
Replication from one ReadyDATA 5200 to another ReadyDATA 5200 on the same subnet. One ReadyDATA has old/broken replication set up but cannot delete/start/stop it. There is an attachment in the original message showing the status. The target does not have any incoming replications showing up. I'm hoping there is a file somewhere that can be edited to remove those old replications.
- JohnCM_SOct 02, 2019NETGEAR Employee Retired
Hi markvalpreda,
Let me check if we can find a way to remove it.
The delta appears to be too large which is why you cannot start it.
What does the job say above the delta?
Regards,- markvalpredaOct 02, 2019Aspirant
Here is a larger screenshot of the two jobs. Let me know if you need anything more.
- JohnCM_SOct 03, 2019NETGEAR Employee Retired
Hi markvalpreda,
It looks like it is still looking for the remote system. It will be best for you to contact NETGEAR support. They may able to remove the jobs through a console or SSH access to the system.
