sg86
Oct 07, 2017Aspirant
ReadyDLNA "no playable media"
DLNA used to work, my TV would pick up folders and files just fine. However, i've recently added some more media that didn't show up, i did a "recan" from ReadyNAS UI (very poor as there is no pr...
- Oct 07, 2017
Hi, i'm running 6.8.0, and yes the model is correct :)
I'm currently looking at Minidlna itself, i've changed DB path to /var/cache/ and rebuilding to see if this "clean slate" works. But any advice on what is happening here would be appreciated
Oct 07, 2017Guru - Experienced User
What firmware are you running?
Your post says you have an RN2120 (OS 6 Arm-based rack-mount unit), is that correct?
sg86
