petemill
Sep 24, 2011Aspirant
ReadyDLNA not compatible with Xbox after RAIDiator 4.1.8
I was on RAIDiator 4.1.6 and everything was working fine wrt streaming to Xbox360 using DLNA. After upgrading to 4.1.8, I ran in to the problem where my ReadyNAS Duo could not be seen by the Xbox u...
tonyr190
Dec 19, 2011Aspirant
i also have the NAS Duo at the moment and i am having exactly the same problems more or less.......
my duo is plugged into my router directly and my xbox is wireless... my xbox can see the duo, however... when i select the duo on it on my xbox i can't access it. but if i stop the dlna service and restart it the xbox still can't access it, lastly when i rescan the media files and then connect from my xbox i can see all the videos and play them fine.
when i turn my xbox off and back on again i have to do the above again.
its so annoying believe me.
version I'm running is 4.1.8
