Jul 07, 2012Guru - Experienced User
ReadyDLNA OS Partition Usage
I just noticed that ReadyDLNA's database and artwork cache are stored on the OS partition (/var/cache/minidlna). On my system that is about 600 MB of the limited OS partition space :shock: Is th...
Etz
Jul 17, 2012Aspirant
Skywalker wrote: Yes, just changing the db_dir setting in the config file will do the trick, and won't get overwritten by firmware updates. We could probably do an addon for this without too much trouble.
Would be really helpful, as db_dir grows expodentially, if you have lots of media files and most users wouldnt feel themselves very comfortable to edit config files by hand.
