Jul 07, 2012Guru - Experienced User
ReadyDLNA OS Partition Usage
I just noticed that ReadyDLNA's database and artwork cache are stored on the OS partition (/var/cache/minidlna). On my system that is about 600 MB of the limited OS partition space :shock: Is th...
mdgm-ntgr
Jul 24, 2012NETGEAR Employee Retired
What model ReadyNAS was this on and what version of RAIDiator? What version of ReadyDLNA is installed on your NAS?
How did you manually edit the conf file, via SSH using vi or some other method?
When does the file get rewritten losing the changes? When you restart ReadyDLNA? When you reboot the NAS? When you make configuration changes to ReadyDLNA via the web-admin interface of the ReadyNAS?
